Hello,
Ich habe eine Honda Accord Tourer aus 2005, full option mit Alpine Sat Navigation.
Der mitgelieferten DVD ist aus 2003 und ich haben eine neues DVD gekauft von eBay (v3.23)
aber es funktioniert nicht :(
bilder;
http://img262.imageshack.us/img262/8127/afb195.jpg
MAP + MENU + RETURN (diagnosis Menu) funktioniert auch nicht mit diesem DVD
Danke für ihre help!
Hello,
bilder;
Try to force download by using "map and zoom down" press and hold for a few seconds , once successful you should hear a fanfare confirming the menu
Phil
Bearbeitet von Phil.UK
If you could be a bit more precise surely someone might be able to help. I still haven't really come to grips with your problem / is it the engine which won't start or is it the satnav unit that isn't working?
If its the sat nav unit is without fault this should help to force an update of the firmware.
You need your Old sat nav DVD .
1. Start the engine.
2. error message appears on screen with old disc inserted.
3. Push 'MENU' and 'ZOOM DOWN' switches simultaneously for 2 seconds.
4. Screen turns to SYSTEM LINK page with a fanfare.
5. Press 'NEXT' switch (opens car staus page).
6. Press 'NEXT' switch (opens yaw rate page).
7. Press 'NEXT' switch (opens diagnosis menu page).
8. Select 'UNIT CHECK'.
9. Select 'FORCE DOWN LOAD'.
System will now start to download the old operating system firmware from the old disc, showing progress on a green bar gauge.
When finished the unit should be able to be started normally.
Should you have a problem concerning the engine of your "set of wheels" there are some blokes who might be able to help if you explain in detail.
Good luck
Phil
