Dear members,
First a short intro, im Rinesh, from Holland. I have an accord CL3 2001.
i want to change the original bose headunit. I have read all the treads on accordforum with (google translation) because i cant speak/write german. Even tread of rolander in tuning guides.
the problem is dat a friend of mine who is going to change the headunit said i even have to replace the bose amp because it is almost impossible to figure out the wiring. But i want to hold evrything as much orgininal as it can, only a new headunit. Can anyone help please?
Thank u very much, and greetings from Holland.
PS. I want to buy this headunit: Eonon D1303, wtih 7 inch display, dvd, bluetooth etc. Any experience?
Hi Rinesh,
First up let me tell you that I don't have the slightest clue. I had a look at the unit you are about to buy and I think your mate is right, you won't be able to fit this without compromising the wiring or without ripping out the entire installation and start from scratch, you could also try to get a harness made specially for your model. though mind you I don't even know whether this exists.
Anyway good luck with it.
