Der neue (Acura) NSX
Acura V10 engine / sports car.
Well, as almost every month / week, “Bestcar” has another look at a possible Acura sports coupe, and some talking about the upcoming Honda V10. Although announced as a “Top Secret” scoop, as always I wouldn’t really put to much emphasis on the accuracy of this information. They also claim though to have had an interview with somebody that has seen a real concept. Here is in short what they say though:
* It will arrive in ’08, together with the introduction of the Acura brand in Japan.
* Honda will give a clear design clue in Detroit in the Acura PR event (that apparently that man has seen).
* V10 powerplant will be a 4.5L, smaller than current BMW’s M5 and the upcoming Lexus V10. They also say that it would have a V angle of 95º, similar to F1 engines, and that for that reason the body will have to be wider. It should reach around 120PS/L with max output of 550Hp. Power is said to come to the wheels through a Semi-AT transmission.
* Platform is said to be a newly developed FR+SH-AWD setup, together with a new suspension design, and inheriting an all aluminium body construction from past-gen NSX.
* Style is said to be more in the line of British GT’s than Italian Ferraris. According to the source, he can’t really find similarities with other cars on the road, although he says that you could say it’s a Honda (Acura), but that you couldn’t think of it as a NSX successor.
* Price would be in line with past-gen NSX (priced around 10 – 12 Million yen), which would be considerably cheaper than Lexus targeted price of 15-20 MYen for their GT-car. Please do not translate those figures into dollars at today’s rates. Car prices in Japan have remained unchanged for really long time despite Yen recent depreciation. For sure overseas market’s prices would be more expensive than just translating the currencies.
Quelle: http://www.templeofvtec.net/news/news-item?news_item_id=640875
  • Antworten 73
Starkes Konzept!!!
Wahnsinns Wagen, Hoffentlich tendieren die wirklich eher zu dem, als zu dem andern Konzept mit dem 3.5-liter V6 - Turbo
Turbolader gehören in keinen Honda, erst recht nicht in das NSX- Modell, was ja alles representiert, wofür Honda steht, das haben die garnicht nötig... 8)
->Fahr' richtig, oder fahr' nach hause!<-
das stimmt heimdall, ich vergas auch dies hinzuzufügen:
NOTE: Before somebody starts another comment thread asking if these are real pics, please note these are COMPUTER GENERATED images. Additionally, these images are NOT OFFICIAL, nor did they originate from Honda. Note that these are basically composite sketches and may very well be based heavily upon an actual photo of an entirely different car. If you're new to the scene, that's how they do things in these Japanese scoop mags.
550 P, nicht schlecht, aber welche?
SAE-PS oder die europäischen? Das geht daraus nicht hervor.
Ich vermute mal, dass SAE-PS angegeben wurden.
edit:550 PS
  • 4 Wochen später...
  • 1 Jahr später...
nicht viel neues, aber was interessantes bzgl. NSX vs. Skyline :D
Kommt ab Minute 2:25
Honda CRX del Sol EH6... verkauft
Accord Coupé 3.0 V6 CG2... verkauft
Honda Accord 2.4 Executive CL9... now white
Corvette C6 LS3...
edit:550 PS
und wo ist der unteschied zwischen SAE-PS und den europäischen?
Um dir diesen ganzen Text zu ersparen (s.u.) habe ich den letzten Satz zusammengefasst. Umrechnungsfaktor ca. 1,02 SAE <> DIN-1 PS
1 DIN PS ist laut DIN 66036 (Deutsches Institut für Normung) definiert als die Leistung, die erbracht werden muss, um einen Körper der Masse m = 75 kg entgegen dem Schwerkraftfeld der Erde (bei Erdbeschleunigung 9,80665 m/s²) mit einer Geschwindigkeit von 1 m/s zu bewegen[4].
Leistung = Arbeit / Zeit =
1 PS = 75 kpm/s = 735,49875 W
Vergleichsweise entspricht dieses etwa der Leistung eines Zugpferdes, das mit Schrittgeschwindigkeit (5,4 km/h) einen 500 kg schweren Karren eine 10-prozentige Steigung hochzieht.
Dem amerikanischen „SAE-PS“ werden die SAE (Society of Automotive Engineers) Richtlinien SAE J1349 und SAE J2723 zugrunde gelegt. In der SAE J2723 ist die Methode beschrieben, wie die Leistung des Verbrennungsmotors ermittelt werden muß und wie die Nebenaggregate bzw. welche Nebenaggregate betrieben werden müssen. Die SAE J1349 gibt die Berechnungsgleichungen vor, wie die am Motorenprüfstand ermittelte Motorleistung auf eine (nach SAE) standardisierte Bezugsbedingung umgerechnet werden muß.
In Europa wird zur Korrektur der Motorleistung die EU-Richtlinie 80/1269 angewendet.
Die Bezugszustände der europäischen Richtlinie und der SAE-Richtlinie unterscheiden sich nicht. Das Gerücht, daß SAE PS ohne Nebenaggregate ermittelt werden, hält sich zwar hartnäckig in Volkes Seele, ist aber eben nur das - ein Gerücht. Der SAE-Korrekturfaktor beinhaltet allerdings einen Wirkungsgrad-Korrekturwert, so dass sich geringfügige Unterschiede der Leistungswerte ergeben.
Eine DIN-Korrektur nach Richtlinie 70020 wird nicht mehr durchgeführt, weil die Unterschiede vernachlässigbar sind.
Als Faustregel zur Umrechnung von DIN zu SAE PS kann man den Faktor 1,02 verwenden. Unter realistischen Bedingungen ist das genau genug, selbst für hartnäckige Haarspalter
Auf jeden Fall ist die Olle da voll auf Drogen :auslachen: und ihr müßt zugeben, der neue Skyline ist auch ein Hammer: für ~78.000 bekommste einen Porschekiller der feinsten Sorte.... :wink:
Gran Turismo6
.....ich bin dann mal weg :D:cool::angel::wink:
Der sieht genauso aus wie das Concept Car von Accord :-P ... So hätten die den Accord bauen sollen und nicht so ein Scheiß fabrizieren X(
So long ...
VW Tiguan Track & Style :wink: & ab 12.08.2016 Audi S3 Limo Facelift
