i think this adapter is on the one side a cinch (which cennects the radio) and on the other side USB... will you connect your DVD/TV modification over usb?
it only has the audio out, it doesn't have any usb port...
i'm going to buy a video interface for the video exit and a switch that change between navi or dvd...
I've seen a couple of people that has done this on Acurazine...
  • 4 Wochen später...
Yes. And it's not easy :roll:
Maybe partial helpful: http://www.lengenfelder.com/html/fse.htm
It's to complex to explain the whole installation.
Please ask, if you have problems.
Just one info to start:
http://www.woerstenfeld.de/acci/radioaus.gif
Pull it to you and a little bit upwards
See also http://www.type-s.ch/site/documents/Umbauten/DVD%20Decken%20Entertainment.pdf
