vtecmoon Geschrieben 11. Dezember 2014 Geschrieben 11. Dezember 2014 (bearbeitet) For Sale: Complete BR Racing BR Series Coilovers set for the Honda Accord 03-08 sedan model Fully height/low and soft/stiffness adjustable (30 adjustable positions) Plug & Play for the 2003-2008 Honda Accord Sedan Models. Comes with 2 keys to adjust the height/lowness of the coilover. The pictures are taken when they just got demounted from the car, so I did not clean them yet! The BR series coilovers use a large 44mm diameter piston in a 53mm diameter damper body to maximise oil capacity. As the damper unit operates, the oil contained within heats up. The viscosity of oil changes as its temperature varies which can lead to changes in the damping characteristics of the unit. BC Racing only use a very high quality oil with their coilovers but go that extra mile to maximise performance and build their BR range with a large 53mm diameter damper body. This increases the capacity of the unit which increases the volume of oil contained which in turn reduces the peak temperature and so significantly improves damper performance. Item is in used shape. Normal wear and tear due to daily use. Love the coilover set as it gives you the stability when driving and taking the corners. With the weather in the Netherlands, unfortunately some paint on the springs came off and it looks little bit rusty. Nothing serious as it works 200%!! The dampers are 200% functional, so no issues here! Again, the picture are taken when they just got demounted, so they are dirty in the pics. Asking Price = €450,- Shipping to Germany/Switzerland = € 45,- Netherlands = €6,95 Pick up possible as well (Amsterdam, the Netherlands) Questions? leave me a message. Tx http://img.photobucket.com/albums/v669/vtecmoon/CL9/20141211_144803.jpg http://img.photobucket.com/albums/v669/vtecmoon/CL9/20141211_144830.jpg http://img.photobucket.com/albums/v669/vtecmoon/CL9/20141211_144909.jpg http://img.photobucket.com/albums/v669/vtecmoon/CL9/20141211_144929.jpg http://img.photobucket.com/albums/v669/vtecmoon/CL9/20141211_144921.jpg Bearbeitet 26. Februar 2015 von vtecmoon Zitieren
vtecmoon Geschrieben 15. Dezember 2014 Autor Geschrieben 15. Dezember 2014 new price = €600,- Zitieren
vtecmoon Geschrieben 29. Dezember 2014 Autor Geschrieben 29. Dezember 2014 (bearbeitet) New price 450,- Shipping not included Bearbeitet 26. Februar 2015 von vtecmoon Zitieren
DózeR Geschrieben 26. April 2015 Geschrieben 26. April 2015 Are the coilovers still for sale? Zitieren
