paapaa Geschrieben 29. Januar 2008 Geschrieben 29. Januar 2008 Hello, My 2.2 i-cdti is now 170 hp and 400nm. Is it any good to buy: Hi-Performance Intake System http://www.mugen-styling.ch/033f9898990c39704/033f9898990e01954/index.html ???? MFG, Kai Zitieren Honda Accord 2006 i-cdti170hp / 400nm 0-100 km/h about 7.75 s (tested with Beltronics FX-2 30.7.2006)80-120 km/h about 5.35 s (tested with Beltronics FX-2 30.7.2006) 0-100 km/h original about 9.1s80-120 km/h original about 6.6s
Acci-Driver Geschrieben 29. Januar 2008 Geschrieben 29. Januar 2008 It doesent´work´s in your CN1.It´s only for gasoline engines.;) Zitieren
paapaa Geschrieben 29. Januar 2008 Autor Geschrieben 29. Januar 2008 It doesent´work´s in your CN1.It´s only for gasoline engines.;) great :schock: thank you for the correct information :)) -Kai Zitieren Honda Accord 2006 i-cdti170hp / 400nm 0-100 km/h about 7.75 s (tested with Beltronics FX-2 30.7.2006)80-120 km/h about 5.35 s (tested with Beltronics FX-2 30.7.2006) 0-100 km/h original about 9.1s80-120 km/h original about 6.6s
elgusano Geschrieben 29. Januar 2008 Geschrieben 29. Januar 2008 The only thing what would be useful is the following filter: http://www.ajr-performance.com/catalog/product_info.php?products_id=390&osCsid=fcd75e8958f6cbc1860c7be05a535f07 Should increase the airflow and minimize the diesel particle... a chipped diesel needs AIR!!!;) I ordered it, but only will get it in 3 weeks:( Zitieren [sIGPIC][/sIGPIC]P.S. Ich find Hondapower.de besser:D:D:D
paapaa Geschrieben 30. Januar 2008 Autor Geschrieben 30. Januar 2008 The only thing what would be useful is the following filter: http://www.ajr-performance.com/catalog/product_info.php?products_id=390&osCsid=fcd75e8958f6cbc1860c7be05a535f07 Should increase the airflow and minimize the diesel particle... a chipped diesel needs AIR!!!;) I ordered it, but only will get it in 3 weeks:( thank you for the info. i will get K&N or Green sportfilter soon. I did notice some difference when i replaced Honda´s original grill with a sportgrill http://www.banzai-tuning.de/images/BT0202_gr.jpg air get more easily to engine and even my neighbour was surprised that what the hell has happened...because now your car gives a little "wooosh" sound every time i accelerate faster :D well thats thrue, it sound better now. I believe you, when chipped, even small changes like the sportfilter may give a little more sound / acceleration. -Kai Zitieren Honda Accord 2006 i-cdti170hp / 400nm 0-100 km/h about 7.75 s (tested with Beltronics FX-2 30.7.2006)80-120 km/h about 5.35 s (tested with Beltronics FX-2 30.7.2006) 0-100 km/h original about 9.1s80-120 km/h original about 6.6s
