Truman Geschrieben 15. Februar 2010 Teilen Geschrieben 15. Februar 2010 ;166872']The turbo is a mitsubishi td04. I got a walbropump and precision injector 440cc. I use greddy e-manage ultimate, that is a piggyback solution. I want hondata, but its to much job to fit the f18b2. But the emanage works fine for me. I have'nt change the compression. I run on 0,5 and 0,7 bar. I just adjust it with a greddy boost controller. If I go N/A with the ATR, what do you recomand then? What is your setup? Hi, nice setup! :party2: There is no big deal to go with Hondata in you car. Just buy a OBD2 to OBD1 harness converter and a P28/P30 ECU. That's it! What kind of header did you got? Is it a custom or one for the H22 ?? Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
scream Geschrieben 26. Februar 2010 Autor Teilen Geschrieben 26. Februar 2010 The header is a f20 turbo header. :) Are you sure it will fit? I have heard that you have to change something more.. Idle valve or something.. Zitieren Honda Accord CG8 turbo power! Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
Absurd Geschrieben 27. Februar 2010 Teilen Geschrieben 27. Februar 2010 Hey "scream", you´ve build an F20 Blue Top Header on F18 block? Went this without problems? regards chris Zitieren Loud exhausts = police magnet Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
Lil Krayzee Geschrieben 27. Februar 2010 Teilen Geschrieben 27. Februar 2010 @ Scream: Do you know if your Accord have a 2wire IACV oder 3wire IACV? The P28 need a 2wire IACV, so i don´t know if you have to change it... The ATR have 3wire IACV so you need an Adapter 3wire to 2wire IACV and the IACV from the Civic Vti 1.8 (MB6). If you use the P28 you will loose the EGR valve and the knock sensors. And i don´t know if the stock OBD port still work... Zitieren Projektauflösung: Civic EJ9, EK4, EK9, K20A, K-Swap Teile https://www.ebay-kleinanzeigen.de/s-bestandsliste.html?userId=6298395 Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
scream Geschrieben 28. Februar 2010 Autor Teilen Geschrieben 28. Februar 2010 Hey "scream", you´ve build an F20 Blue Top Header on F18 block? Went this without problems? regards chris No, the turbo manifold is a f20 manifold. The engine is stock f18b2 ;) Zitieren Honda Accord CG8 turbo power! Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
scream Geschrieben 28. Februar 2010 Autor Teilen Geschrieben 28. Februar 2010 @ Scream: Do you know if your Accord have a 2wire IACV oder 3wire IACV? The P28 need a 2wire IACV, so i don´t know if you have to change it... The ATR have 3wire IACV so you need an Adapter 3wire to 2wire IACV and the IACV from the Civic Vti 1.8 (MB6). If you use the P28 you will loose the EGR valve and the knock sensors. And i don´t know if the stock OBD port still work... Its the same as the ATR. You have to use the civic vti IACV. Thats right, you will loose it. Handata crew also said that the immobilizer system doesnt work.. but I dont know.. Zitieren Honda Accord CG8 turbo power! Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
Lil Krayzee Geschrieben 17. März 2010 Teilen Geschrieben 17. März 2010 Do you know if you can raise the rev limit with Greddy Ultimate on the Accord? Zitieren Projektauflösung: Civic EJ9, EK4, EK9, K20A, K-Swap Teile https://www.ebay-kleinanzeigen.de/s-bestandsliste.html?userId=6298395 Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
scream Geschrieben 22. März 2010 Autor Teilen Geschrieben 22. März 2010 I'm not sure. I dont think so.. I cant find the manual... Zitieren Honda Accord CG8 turbo power! Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
wEEd Geschrieben 23. März 2010 Teilen Geschrieben 23. März 2010 We wanted to see him in action Zitieren http://img9.imageshack.us/img9/2074/weed2k.jpg Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
Illya Kuryakin Geschrieben 23. März 2010 Teilen Geschrieben 23. März 2010 2nd that! [scream], why don't you make a nice video of the whole set-up. I'd _so_ like to find out what kind of sounds it makes :D Zitieren Link zu diesem Kommentar Auf anderen Seiten teilen Mehr Optionen zum Teilen...
